I would like to try translating an ArcGIS layer file generated in ArcGIS 10.5 (32bit version) into MapInfo format using FME 64bit version however, the option is greyed out and the only reason I can relate this to is that the ArcGIS I am running is 32bit? Is there a way around this or should I try downloaded the FME 64bit version. I currently only have a trial license because I want to work out if this works before we buy a license. Regards Sandi
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
