I answer myself so others don't have to spend time looking for the answer.
The AutoCAD Global Width setting is stored in the autocad_width attribute in FME. If the advanced reader parameter "Stora Bulge Info" is turned on you can retrieve the attributes autocad_start_width and autocad_end_width if they differ from the Global Width.
We use 3 different kinds of cookies. You can choose which cookies you want to accept. We need basic cookies to make this site work, therefore these are the minimum you can select. Learn more about our cookies.
