How can we draw UML of CityGML File using FME? Is it possible to do so?
Using FME to build UML of CityGML File
Best answer by virtualcitymatt
Hi @vignesh
I suspect that this would be more effort to do with FME that it would be just to manually create them (or use a specialised tool). If you has a whole lot of diagrams which you needed then it might be worth it, however, I can't really see how you could get the connections/relationships to work.
If perhaps there was a third party tool that ran on command line or a python library for this kind of thing then you could use the SystemCaller or PythonCaller, respectively, and use FME as a wrapper to parse the CityGML.
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
