Replacing a point feature with 3D objects (sketchup or collada)
I am trying to replace point features (shapefile format) with 3D objects (sketchup, collada, etc.)
I thought geometry replacer will carry out the task. But, I am not able to do this
Pls help. Thanks in advance
pratap
Forum|alt.badge.img+11
  • May 7, 2018
Do you want to convert point data to 3D solid?
Pratap
Hi
I have to replace that point data with a 3D object. ( say, point with a collada model of tree/3D solid)
pratap
  • May 7, 2018
Is it possible to send sample for better understanding
I referred to this solution. And I was following this https://knowledge.safe.com/articles/664/use-input-points-to-place-3d-collada-models-in-kml.html
4th step was not clear to me. nodes.zippole.zip
point dataset is Node.zip folder
3D object is in pole.zip
