Pass datetime value in Webhook JSON Body to datetime workspace?
  • April 20, 2022
  • 40 views
pmcpherson
Forum|alt.badge.img+9
I have a working Automation that is triggered by either a Schedule block or a Webhook block. It includes a number of "run workspace" actions in series, the first of which currently includes user parameters with values that are fixed in the Automation, one of which is a datetime parameter. I would like to pass a datetime value in the body of the webhook POST, but it appears the first workspace block does not show the "Use a value from upstream keys" for the datetime user parameter, presumably because it is not an ordinary string. Is there a way to accomplish this without changing the user parameter in the workspace to an ordinary string?
keziaatsafe
Forum|alt.badge.img+7
Hi @pmcpherson​ ,
From my testing, it looks like you will need to change the user parameter type from DateTime to a different one such as text. Using a different type will then allow you to select the Event Time, Output Key like so:
EventTimeIn my log, the Event Time key was uses FME Date/Time format: yyyymmddhhmmss
Log
Hope this helps!
