Extract data from a database to a csv file and upload to s3
New to FME. I roughly know the first half, i.e. extract data to csv file is simple. But how to get the csv writer to trigger the next step of the workflow to upload it to s3 bucket? The writer has no output.
Thanks!
Best answer by david_whiteside
You could use FeatureWriter which has output ports to trigger an S3 uploader when successful.
FeatureWriter is a transformer that works just like a writer but allows for the continuation of the workbench
  • April 12, 2017
The easiest is to have two workspaces.
Workspace 1:
  • Creator
  • WorkspaceRunner to execute workspace 2
  • S3Uploader
Workspace 2:
  • Read from database
  • Write to CSV
  • April 12, 2017
Agreed, great solution. Even easier than using the WorkspaceRunner.
  • April 19, 2017
Thank you both David. Gonna give it a go.
