I want to apply the 'DonutBuilder' transformer to several polygon layers, the output layers will be merged into one polygon layer containing the combined dropped 'holes'. How can i achieve this?
  • May 30, 2017
  • 8 views
gio
Forum|alt.badge.img+15
  • May 30, 2017
use a featurereader or advanced reader, aply
DonutBuilder grouped by feature type (if needed), keep holes.
Filter non-holes using a tester (DonutBuilder creates an attribute "_hole_flag" you can test on).
Use a dissolver.
