I'm not sure what words to use, again, to find my answer so I'm just going to ask. I'm new to Regular Expressions, and not an FME wizard by any means
I need to, inside a loop, take text that looks like this: (i'd like to avoid using blocking transformers if possible at this stage in my workbench)
OKC1D,790 [55559]|OKC1D, 791 [272]|OKC1D, 792|OKC1D, 796|XD, 4-6 [DEAD]
And make it look like this:
OKC1D,790 [5559]|OKC1D, 791 [272]|OKC1D, 792 [272]|OKC1D, 796 [272]|XD, 4-6 [DEAD]
With string replacers and searches I can get this:
OKC1D,790 [5559]|OKC1D, 791 [272]|OKC1D, 792|OKC1D, 796|
I'm able to select what's in the brackets with:
but I get 5559 and 272, I need a way to select the last matched group, 272, there are cases where it may be more than 2 match groups but I think that If I can just select the last one it should work
https://rubular.com/r/r2TsFBPPy19hFO
Any regex wizards out there that may be able to help me, OR suggest a better way in FME to do what I want that will work inside a loop
Thank you
