How could i get lines crossing polygon from two side
  • March 3, 2020
  • 7 views
gogopotter90
Forum|alt.badge.img+13
i have many lines with different id inside the polygon ,some of lines crossed the polygon from both side and some not as picture .
overlaps equal 1 in any lines intersected with polygon even if it is intersected from one side or two side
but i want to extract only the lines that intersected only from two side .
i used lineonarea with tolerance automatic but the output overlaps =1
i used spatial relator but always i got the same output with any transformer overlaps =1
it will be nice ,if someone advice me how could i know which lines intersected two times or one time
i used tolerance Automatice but no changes in output
Thanks in advance
@gogopotter90 SpatialRelator should be able to tell you if a line crosses or overlaps a polygon. Check the FME User Documentation on Spatial Relations Defined
