How can I convert with "AttributeCraetor". For example, I want 123,34 to 123.34. commas to dot thanks
Best answer by caracadrian
If you want to replace commas to dots in AttributeCreator use the ReplaceString function:
@ReplaceString(@Value(attribute),",",.)
Don't forget to enclose your comma in double quotes.
  • April 29, 2021
The easiest would be to use the StringReplacer.
caracadrian
Forum|alt.badge.img+23
  • April 29, 2021
  • April 29, 2021
thank you. I've been using FME for 2 weeks. It worked .
