Writer Adobe Geospatial PDF: Feature Type name
Hello,
I'm using the Writer "Adobe Geospatil PDF" and I want to generate the Feature Type Name by using @Value(fme_basename).
The result (filename) is "@Value(fme_basename).pdf".
Any idea?
Thank you very much!
Bernhard
danilo_fme
Forum|alt.badge.img+44
  • January 9, 2018
Hi @fme_blog,
On Write you need to choose by fme_basename:
And the Navigator there is the Option Fanout Dataset. The configuration Fanout Expression = fme_basename:
Thanks,
Danilo
danilo_fme
  • January 10, 2018
Hi @fme_blog
Did you have sucess?
Thanks,
Danilo
  • January 12, 2018
Hi Danilo,
sorry, I'm too late ...
Thank you very much for your help! Yes, it works ...
Bernhard
danilo_fme
  • January 12, 2018
fme_blog wrote:
Hi Danilo,
Bernhard
Hi @fme_blog ,
Not Problem. I'm very to help you.
Thanks,
Danilo
