I have been using this example:
https://knowledge.safe.com/articles/1117/data-distribution-with-web-maps.html
and building my own verison using our own data. I have been asked if it can stream the data to the web map once the button has been ticked for a certain dataset so the user can see the data before they request it.
I.E. in the example above, once you have drawn your polygon, you click on BusRoutes and the bus routes inside of the polygon would then draw up on screen so the user can see what they are about to download.
Can this be done?
@aaronkoning @LauraAtSafe
