Archived
Change icon color to green if there's Startup or Shutdown scripting
Related products:FME Form
samisnunu
Often me and my co-workers share workspaces between others, but we might not be aware of Startup/Shutdown Python scripts existence that use the published parameters, so for example, if one deleted a reader where the script utilizes, it will definitely encounter an error.
My idea is an alternative to other ideas:
- https://knowledge.safe.com/idea/27309/startup-and-shutdown-scripts-with-regular-transfor.html
- https://knowledge.safe.com/content/idea/52718/startupshutdown-scripts-on-the-canvas.html
How about turning the color of the Scripting icon of the Navigator window into green , as well as the corresponding tree child to indicate existence of a script in the workspace once filled out. ( see snapshot for illustration as a draft idea.)
