Archived
True Looper
Related products:Transformers
  • October 25, 2019
  • 5 views
I'd like to see a Creator that can take in a list, SQL Statement, etc... That will grab the first item and FULLY run through the whole workspace and then go back to the beginning , grab next and do again. I have massive amounts of shape files on an S3 bucket that I need to grab one at a time and process. The server wouldn't need a huge harddrive as I can delete before getting next item. Seems like a simple thing to do, but has been very tough to do. I still can't do it effectively.
jdh
Forum|alt.badge.img+28
  • October 25, 2019
The classic way to do that is with a controller workspace and a worker workspace. The worker workspace processes the data and has as a parameter the file to process. The controller workspace contains a Directory and File Pathnames reader and a workspaceRunner. This triggers the worker space once for every feature read in by the pathnames reader.
Alternatively, you can use batch deploy.
