Difficulties in generating contour lines at a bridge
Hi everyone. I am somehow stuck in generating contour lines at a bridge. I have a 3D Surface and when I use the contour generator to generate the line, I get weird results near bridges. I hope someone can help me!
See attached screenshots.
  • November 1, 2013
Sorry, the pictures are too big, and I could not figure out how to edit my question... use right click and view image to see the whole picture.
  • November 4, 2013
if you have the river bed surfaces, consider using them as breaklines for the ContourGenerator. Consider also experimenting a bit with the surface tolerance value.
David
