DWG to DWF
Hi
I am trying to convert a DWG file (AutoCAD 2010) format into AutoDesk DWF file format. The DWG file is an architectural drawing file and include various blocks, hatches, mtext and even XREF.
When I convert DWG to DWF from AuoCAD environment the output is very clear without any loss of objects as shown below
But when I convert DWG to DWF using FME Desktop 2015.1.3.0 the output is not at clear, looks distorted and has missing objects as shown below.
I tried various settings but still no success. Please let me know if you have any ideas or solutions
xiaomengatsafe
Forum|alt.badge.img+3
Hi @sun761980. While we wait for an expert that might know more about this, just curious, would you be able to try this workflow in FME 2018.1? And see if things works better in the latest version? Thanks!
sprongandre
Hi @sun761980
When I want to convert dwg to dwf, my dwf is empty :-S.
Could you post an example workbench?
Thanks!
