undensifier
  • November 29, 2017
  • 15 views
nath
Is there a transformer that undo a densifier? I used the densifier to get a better snapping with points, but after the snapping I want to get rid of all that vertex because the file is getting too heavy.
Thx!
  • November 29, 2017
Hi @nath, the Generalizer with a generalizing algorithm might help you.
nath
  • November 29, 2017
Thx, i have used Deveau, i'm not sure if that's the best method but i do have much less vertexes :-)
