Regular expression in StringReplacer
  • February 10, 2020
  • 9 replies
  • 485 views
umapper1
Forum|alt.badge.img+5
Hi there!
I'm trying to get a Regex search and replace going but my poor regex skills are letting me down. I'm trying to obtain the first 3 (or 4) digits in an existing attribute string and into a new attribute using the StringReplacer but can't get the right formula. I only want the first set of numeric values.
PS. I'm sure this can be done in a single AttributeCreator transformer using a string function too?
Any help would be appreciated!
Best answer by erik_jan
And this will work too, getting the first number in _first_match (in my example 600):
erik_jan
Forum|alt.badge.img+17
  • February 10, 2020
How about another approach:
Use AttributeSplitter (split on whitespace) to split into a list.
The use the StringSearcher on _list{0} using the Regex \\d to find the number.
Hope this helps.
erik_jan
  • February 10, 2020
  • February 10, 2020
@umapper1 Unfortunately StringReplacer doesn't honour substrings - so you're () don't help. Try:
\\d{3,4}\\s
But then in your replacement string, add <space> after the replacement value
umapper1
  • February 10, 2020
Perfect thanks!
  • February 11, 2020
Yes you can do that with a string expression too.
For example, this expression returns the first 3 or 4 consecutive digits in a specified string. Assuming an attribute called "_line" stores a text line such as "CLH800 040PVC TEL TOP T101".
@ReplaceRegEx(@Value(_line),"^\D*(\d{3,4}).*",\1)
  • February 11, 2020
Just be aware the expression returns the same string as the input string if it doesn't contain a matched part. If there could be a case where the input string wouldn't match the regex, it would be better to use the StringSearcher transformer.
umapper1
  • February 11, 2020
Thanks Takashi! this is actually what I was chasing - the expression
jelle
Forum|alt.badge.img+16
  • February 11, 2020
\\d{3,4}\\s
Hi Mark,
just out of curiosity, what do you mean with 'StringReplacer doesn't honour substrings '? In the example below, I swap 'street 24' to '24 street', by referring to '\\2' as the second substring and '\\1' as the first.
  • February 11, 2020
jelle wrote:
Hi Mark,
@jelle - you're correct. I completely forgot about that hidden gem!
From our documentation:
If replacement text contains \\#, where # is a digit between 1 and 9, then it is replaced in the substitution with the portion of string that matched the n-th parenthesized subexpression of the regular expression.
So in the StringReplacer the regex could be: \\d{3,4}(\\s)
and the replacement text: @Value(_replacement)\\1
where \\1 preserves the <space>
