i have three splitted tables how could i create color line per line for the body of table and set specific color for each main header of the table
  • June 16, 2020
  • 4 views
gogopotter90
Forum|alt.badge.img+13
i have as output 3 splitted tables from FME but i would like to add background color to the main header of each table and add different color line per line for each row .
if there is any idea to create table it will be nice but if not ,i would like to change the color so i can recognize the main header from the body of the table .
is there any way to change the background color depend on amoount of rows at each table ,bcs no, of rows changes always .
FME 2018
Thanks for help
germang
Forum|alt.badge.img+12
  • September 21, 2020
Are you using an Excel writer to create these three tables?
If so, you can use a Tester or a TestFilter transformer to filter the data based on the amount of rows and then use separate ExcelStyler transformers for each different table before sending the data to the writer
