Archived
Show Queue Description on Run Workspace Screen
Related products:FME Flow
  • August 25, 2022
  • 4 views
The User can select a queue on Run Workspace, when the admin creates queue admins can add a description of the queue. But there is no way in the server for the user to see the queue description.
Usecase: We have 3 queues, Small, Medium, and Large, each queue has a specific size of the engine associated which is described in the description field. e.g. small = t3.large 2 CPU 8GB Ram. This information is crucial for user consumption when the user is starting the job on a specific queue to understand what size of the engine the user is going to use when they run the job and if is it the right size of the engine for the job they are going to run or not.
LizAtSafe
Forum|alt.badge.img+15
  • February 8, 2024
Updated idea statusGathering InterestArchived
Idea merged into:
All the votes from this idea have been transferred.
