If I run this from desktop works fine. but when I publish it to the server. It gives error in processmonitor log as "No FME Floating Licenses are available. Contact your distributor to purchase additional licenses."
Other workspaces without chainig works fine. Is this something to do with licensing?
Cheers
Best answer by david_r
looks like you're trying to run fme.exe on your server, where you probably haven't got any FME Desktop licenses. This is not something I'd recommend, as you're effecively treating FME Server like a desktop machine and thereby losing out on a lot of server-specific functionality.
We use 3 different kinds of cookies. You can choose which cookies you want to accept. We need basic cookies to make this site work, therefore these are the minimum you can select. Learn more about our cookies.
