Generate lyrx file for ArcGIS Pro?
dannymatranga
Forum|alt.badge.img+5
Does anyone know of a way to use FME to generate a .lyrx file with symbology that I could then use in ArcGIS Pro?
I think a lyrx file is just XML under the hood? Making and remaking layers in ArcGIS Pro is a pretty huge pain point for me, and I'd love to see someone make a transformer / writer to help with this, so that I can just specify a data source, specify symbology parameters and click 'Run' in FME to generate this > add to ArcGIS Pro, instead of using ArcGIS Pro's laggy interface to click around in the symbology pane.
@mark2atsafe​ thought you might know of a solution? Thank you
Forum|alt.badge.img+48
If you open a .lyrx file in a text editor you'll quickly see if it's XML or not. If it is, and you know the schema, you should be able to generate them using FME.
dannymatranga
  • June 29, 2023
It looks like it's actually JSON. The only problem is writing the JSON updates back to .lyrx with FME?
Python CIM access—ArcGIS Pro | Documentation
