Hi, I would like to list all FME Flow users that are currently disabled using the rest API or any other method.
Is this possible?
Thanks,
Marc
Untested, but it seems you should be able to use this endpoint to get a list of all the defined accounts:
https://docs.safe.com/fme/html/FME_REST/apidoc/v3/index.html#!/security/accountsList_get_0
You can then check the attribute "account.enabled".
27 votes
16 votes
15 votes
14 votes
13 votes
9 votes
7 votes
6 votes
5 votes
Already have an account? Login
Sorry, we're still checking this file's contents to make sure it's safe to download. Please try again in a few minutes.
Sorry, our virus scanner detected that this file isn't safe to download.
We use 3 different kinds of cookies. You can choose which cookies you want to accept. We need basic cookies to make this site work, therefore these are the minimum you can select. Learn more about our cookies.
