Is it possible to use a dynamic writer to update? I want to read multiple feature classes, join each feature class and then update the joined records in a different database. Matching columns are not available when selecting Update feature opera
Is it possible to use a dynamic writer to update? I want to read multiple feature classes, join each feature class and then update the joined records in a different database. Matching columns are not available when selecting Update feature operation.
