I am new to FME ..but now at least I know how to use different transformers in FME and to create a workbench and export the related outcome into a CSV or other file formats I want to use for further analysis.
Now, I am keen to learn the automation process...i.e. instead of using the similar transformation for so many times... I am looking for the Python code for the same...which I can convert to make process automated when I have new data set to work with.
Any help on this will be really appreciated.
