Read file with empty column name
geo-x
Participant
  • Participant
Dear community,
I need to read a txt file who have empty column names like that :
Sans titreHow can I manage my reader for having all columns ?
Thanks for your help.
nielsgerrits
Forum|alt.badge.img+52
You can use a CSV reader and set the Field Names Line to 0, the Data Start Line to 1. Then all columns are named col0, col1, col2, etc. Then you can remove the header with a Tester (col1 = number) and use an AttributeRenamer to rename col0 to number etc.
geo-x
Participant
  • Participant
  • May 23, 2022
Hi @nielsgerrits​
If I do that, I've any data and I can't load my dataset.
nielsgerrits
geo-x wrote:
Hi @nielsgerrits​
Can you share a sample of your input? When I recreate a CSV of your screenshot I can configure the reader this way, so I wonder how your sample looks like.
geo-x
Participant
  • Participant
  • May 23, 2022
Yes of course
nielsgerrits
This is how it works for me.
Creator --> FeatureReader.
FeatureReader CSV Parameters:
CSV Parameters2021 workspace attached
geo-x
Participant
  • Participant
  • May 23, 2022
I'm jealous 😂
For me it doesn't works image
Forum|alt.badge.img+31
  • May 24, 2022
Can you check what is set in the Advance settings?
nielsgerrits
Are you using a dynamic input instead of a hard coded? Then you wont see values in the preview but the functionality works.
Also, when using a dynamic process, the attributes col1, col2, col3 will be unexposed so you need to expose them manually using the AttributeExposer.
geo-x
Participant
  • Participant
  • May 24, 2022
Yes, this is my settings :
