About Autocad Group entity
vigood
Forum|alt.badge.img+3
hello?     There are some groups in my AutoCAD DWG data. Groups in Autocad means a whole that when you select a group in AutoCAD ,you'll select all element in it. But when I read these groups data in FME, they'll be auto exploded even I set the 'read group' parameter to 'yes' in Reader. And I could not find some relationship between those features which are one group. How can I resolve this problem in FME.
Best answer by fmelizard
FME reads the groups as separate features, which have no geometry, but do have a list (autocad_entity{}) of the entities that are part of the group.
I have created an FMEpedia page showing how to use the Group features to recreate the AutoCAD aggregation:
http://fmepedia.safe.com/articles/How_To/Use-AutoCAD-Groups-in-FME
Dave Campanas
Product Specialist
Forum|alt.badge.img+19
  • June 18, 2013
Did you try referring to some DWG format attributes e.g. autocad_group_name?
Takashi
vigood
  • June 18, 2013
I've tried your suggestion.  Whether or not to set 'read groups' to 'yes' in Reader parameter, then I used a AttributeExposer to expose 'autocad_group_name',  output the data to Data Inspector,  but I couldn't see any attribute named 'autocad_group_name'. It seems this method dose not work.
  • June 19, 2013
Does the setting RESOLVE_BLOCKS have any influence on the result?
I know blocks are not the same as groups, but if the group is read as a block it might get exploded if the reader is set to "explode" blocks?!
/Tim
fmelizard
Forum|alt.badge.img+17
  • June 21, 2013
Dave Campanas
Product Specialist
