I'm hoping to use the Emailer transformer with FME Desktop to send an email with attachments using Microsoft Exchange via Outlook Web Access. Should this be possible using this transformer? Or maybe using some other method?
Emailer Transformer with Outlook Web Access
Best answer by david_r
It should be possible, granted that the Exchange server has been configured for SMTP access. You may have to contact the Exchange server admin, as this is typically something that must be manually activated.
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
