OSM to PostGIS keeping all tags
  • January 28, 2019
  • 10 views
btl
Forum|alt.badge.img+3
Is there a way process OSM data so that I organise the most important tags into separate attributes while keeping all other key/value pairs e.g. by dumping them into another attribute called "othertags"?
For example; an entry in my Highway table might look like this:
highway
trunk
lanes
2
oneway
yes
width
12
othertags
"surface"=>"asphalt", "name"=>"Ermine Street", "maxspeed"=>"70", "lit"=>"no", "ref"=>"A1", "name:en"=>"Ermine Street", "maxwieght"=>".....
Basically I don't want to lose any info, but I don't want to expose all tags to potentially several tens of mostly useless attributes.
  • January 28, 2019
I think the most sensible solution would be to store the "othertags" in a separate table as key/value pairs and with a foreign key pointing back to the main table entry.
You could use a StringSearcher or a small Python script to split up the "othertags" to key value pairs. If your data doesn't have a unique global ID, you can create on using the Counter.
The othertags table could e.g. look like this:
osm_idkeyvalue1surfaceasphalt1nameErmine Street1maxspeed70
