Released
Support for Azure Cosmos DB
Related products:FME Form
  • October 13, 2017
  • 5 views
fmelizard
It would be nifty if FME could support Azure Cosmos DB.
I have some ideas for using it, but I wonder what others want to do with it?
[Update] in FME 2017.1 we've renamed Microsoft Document DB to Microsoft Azure Cosmos DB, which support the JSON document store (through SQL API,as referenced here). It would be great to hear what other data models you are interested in using FME to integrate and transform.
xiaomengatsafe
Forum|alt.badge.img+3
This format is available in FME 2017.1 (download the latest FME here). If you feel the current implementation doesn't address your need, please feel free to post a separate Idea.
