Unable to write to the file when using gltf transformer
mustafa.salah
Hello
I frequently receive this error message when exporting Revit geometries as gltf, though the same transformer was able to write to the same folder:
"Unable to write to the file 'Z:\\fmeserverdata\\resources\\data\\destination\\Extraction\\rme_advanced_sample_project\\2009-01-Technical School\\2022-05-17\\GEOMETRIES\\GLTF\\Mechanical Equipment\\M_WSHP - Horizontal - High Efficiency - 7-18 kW - Left Return - Right Discharge\\ac8b9fc6-24ff-4c3b-a4c6-035f009e396e-0005e3ef.gltf'"
Any advise?
Best answer by siennaatsafe
Hi @mustafa.salah​ ,
Can you confirm if long file paths are enabled on your system? https://community.safe.com/s/article/windows-enable-long-file-path-support
Also, I don't believe this is your issue but we do highly recommend keeping your FME Workbench and Server on the exact same version to avoid any unexpected errors.
nampreetatsafe
Forum|alt.badge.img+12
Hi @mustafa.salah​. Could you possibly provide your entire log file? Are you running this on FME Desktop or FME Server? What version of FME are you using?
mustafa.salah
Please find attached the full log file.
The workspaces were created using FME Workbench 2021.1.3.1, and the automation was created on FME Server 2021.2 Build 21797 - win64.
siennaatsafe
Forum|alt.badge.img+10
mustafa.salah
Thanks a lot, this solved the issue.
