Creating a SchemaFeature and mapping values to it
Hi
I have managed to create new attributes for a SchemaFeature:
And when I set the Excel Writer Schema Sources to "Schema From Schema Feature" I am outputting an excel spreadsheet with the new column headers as I require.
However, I can't work out how to populate these column headers! I tried to populate them in AttributeManager like so:
But then in the excel spreadsheet the values of the column headers replaced the column headers themselves.
I seem to be missing one vital step here but I can't work out what it is.
Thanks,
  • October 19, 2017
Your screenshot isn't visible...
  • October 19, 2017
Unfortunately my computer won't let me copy screenshots so I will have to type what I've done (see below).
I can create the new column headers using the AttributeCreator with the parameters as such:
New AttributeAttribute Valueattribute{0}.name@Value(_candidates{0}.Node_Label)_Distanceattribute{0}.fme_data_typefme_decimal(10,2)attribute{1}.name@Value(_candidates{1}.Node_Label)_Distanceattribute{1}.fme_data_typefme_decimal(10,2)attribute{2}.name@Value(_candidates{2}.Node_Label)_Distanceattribute{2}.fme_data_typefme_decimal(10,2)
But I can't work out how to populate the new attributes names with the actual values (which are coming from another list).
Thanks,
  • October 19, 2017
Thanks,
For screenshots, try uploading to e.g. imgur.com and inserting the link here:
