I want to write a DWG containing a mesh (it is one feature in FME), but it always gets split up into strips with a specific number of vertices like there is a limit (see image). Is there anything I can do about it or is it just a restriction by the DWG format? I'm not very familiar with the DWG datatype, so maybe there is another autocad entity that is better suited?
Be the first to reply!
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
