Released
VertexCreator allow insert at index mode for points
Related products:FME Form
  • February 8, 2017
  • 4 views
jdh
Currently the VertexCreator in Insert Point at Index Mode will reject point features as invalid. These features would benefit from Insert point at index 0 in cases where the orientation of the line matters.
This has been fixed in FME 2018.0 - Specify 0 with "Insert Point at Index" to insert a vertex at the beginning of a feature or "Add Point" to add it to the end.
We plan to loosen this up even more for FME 2019 . So if you have a two vertex line and you set Insert Point at Index = 100 it'll still add the point as third vertex. Same for -100. It will insert before the current vertex 0. At the moment, an index out of range will cause the feature to be rejected.
