FME reprojection is taking too long to process.
  • November 21, 2018
  • 6 views
We are syncing data of Smallworld with GSDS (Geo Spatial data Store) which is an oracle database, reprojection is taking very long time to process. It takes more than 2-3 hours to process the same number of records which used to get processed in half an hour before August 2018. We have custom coordinate system defined for reprojection. What could be wrong here? how can this issue be fixed. Please help
mark2atsafe
Forum|alt.badge.img+43
  • November 21, 2018
Can you share the log file? That would help to analyze what is happening. Also, is there anything else in the workspace. It can be hard sometimes to tell from the log whether the slowdown is reading, writing, or transforming. Sometimes a little experimenting is required.
