How do I translate GTFS data?
I'm trying to convert GTFS transport data to Shapefile using  FME 2020.0.0.0 (20200309 - Build 20200 - macosx) Quick Translator, but I get this exception:
<< FME 2020.0.0.0 (20200309 - Build 20200 - macosx)
FME Home Edition (node locked-crc)
Temporary License: 234 days left.
Machine host name is: YOS0897
Operating System: Mac OS X Version 10.15.3 (Build 19D76)
Copyright (c) 1994 - 2020, Safe Software Inc.
Safe Software Inc.
Creating reader for format: General Transit Feed Specification (GTFS)
Trying to find a PYTHON plugin for reader named `GTFS'
The workspace does not contain user Python. FME will attempt to use a Python 3.7+ interpreter
Using Python interpreter from `/Library/FME/2020.0/fmepython37/lib/libpython3.7m.dylib' with PYTHONHOME `/Library/FME/2020.0/fmepython37'
Python version 3.7 loaded successfully
Python Exception <ModuleNotFoundError>: No module named 'gtfs'
Could not create Python Reader `GTFS'
Could not create Python Reader `%0'
Failed to obtain any schemas from reader 'GTFS' from 1 datasets. This may be due to invalid datasets or format accessibility issues due to licensing, dependencies, or module loading. See logfile for more information
FME Session Duration: 2.5 seconds. (CPU: 1.0s user, 0.2s system)
END - ProcessID: 3240, peak process memory usage: 105676 kB, current process memory usage: 91516 kB
Program Terminating
Translation FAILED. >>
I have Python3 already installed, as well as the GTFS package. How do I get the Quick Translator to work with this?
Thank you.
Yoshi
danilo_fme
Forum|alt.badge.img+41
  • November 10, 2020
Hi @yoshinobu​
Are you try to do this convertion into FME Desktop Workbench Generate Workspace, using the Reader General Transit Feed Specification (GTFS)?
Reader_GTFSThanks,
Danilo
  • November 10, 2020
Hi Danilo,
When I try the Workbench and select the GTFS reader, I receive a message saying that it's not supported by this FME licence. When I try the Quick Translator, I get above Python message.
Ironically, I'm evaluating FME Desktop's ability to translate GTFS data to Shapefile and KML, so it's important that I get this to work.
Yoshi
