merge but by group
Good day,
I have two tables with records that I want to join together based on the category attribute:
1.table:
First attribute is the client, second the category.
MAAS CA
MAAS IND
MAAS SWE
BWL CA
BWL NO
BWL EE
2.table:
First attribute is the cell, second the category.
CA345985 CA
CA290456 CA
IND789345 IND
SWE563843 SWE
EE621984 EE
NO893476 NO
EE972086 EE
IS856145 IS
What I would like to have as a result is to create an excel report per client. The report should only contain the cells whose category matches with the client ones in table 1.
e.g. MAAS_report.xls containing:
CA345985
CA290456
IND789345
SWE563843
and BWL_report.xls containing:
CA345985
CA290456
NO893476
EE972086
This is only a simplified example. I would need to create these reports for hundreds of clients which all should be compared to table 2.
Your help is really appreciated.
Forum|alt.badge.img+48
You can use a FeatureMerger to join both datasets on the category attribute, make sure to create a list and then use a ListExploder to turn that into individual features again since there's a one-to-many relationship.
Then you can set a fanout on the Excel writer, using the client attribute as the filename, so for each unique client name you will get a new Excel file.
I've attached a template with this workspace and the sample source data:
none2none.fmwt
Forum|alt.badge.img+31
  • July 18, 2017
Why would BWL report not contain EE621984?
  • July 18, 2017
If the above should in fact include EE621984 then I would aggregate your first table, Group By Category, and create a list called CLIENT and join this to the supplier on a featuremerger
The second table would then be joined to the requestor port and merge on the CATEGORY attribute, after merging use a LIST exploder which will create a feature per cell per relevant client
  • July 18, 2017
@redgeographics method is neater though :-)
[takes bow]
erik_jan
Forum|alt.badge.img+17
  • July 18, 2017
Depending on the source format (and from the word table I take it is a database), you could also use the SQLCreator and have the database do the joining:
Select * from Client_table t1, Cell_table t2 Where t1.client_code = t2.client_code.
Then write the Cell_name and use the Client_name as attribute to name the output file.
Forum|alt.badge.img+19
  • July 19, 2017
Another thought. The InlineQuerier (SQL statement) could be used here regardless of the source format.
join-tables-with-inlinequerier-example.fmwt (FME 2017.0)
