Released
LDAP experience should be improved.
Related products:FME Flow
siennaatsafe
fmelizard
danilo_fme
ml56067
roland.martin
  • siennaatsafe
    siennaatsafe
  • fmelizard
    fmelizard
  • danilo_fme
    danilo_fme
  • ml56067
    ml56067
  • roland.martin
    roland.martin
fmelizard
Migration Note: Idea originally posted on 2015-10-29
rylanatsafe
Forum|alt.badge.img+13
  • April 22, 2024
@helmoet - You may also be interested in voting for this Idea and mirroring your comment there! https://knowledge.safe.com/idea/45158/general-ldap-support.html
rylanatsafe
  • April 22, 2024
@ml56067 @rollo @ogayte and anyone else interested in this Idea... It would be very helpful (!!) if you could add some comments that will help more specifically define this goal of "improving the LDAP experience." Without a clear definition, I feel this Idea is subject to either A) never being satisfied, or B) marked as "Completed" as part of general updates to the product.
rylanatsafe
  • April 22, 2024
For FME Server 2017.0 and Newer, Active Directory configuration is now done entirely within the FME Server Web Interface!  https://docs.safe.com/fme/html/FME_Server_Documentation/Content/WebUI/Active-Directory.htm   Should this not address any concerns related to this idea posting, please let us know by leaving a comment. Alternatively, you may consider creating a new idea with a focused description.
erik_jan
Forum|alt.badge.img+17
  • April 22, 2024
I posted a similar idea some time ago:https://knowledge.safe.com/idea/41478/fme-server-2017-ad-import-improvement.html
helmoet
Forum|alt.badge.img+8
  • April 22, 2024
We experience trouble accessing Active Directory through LDAPS; filed support request.
