Contour generator - problem with breakline
Hi guys,
I have DTM files in ASCII GRID format and I need to generate contours from this files. Everything works fine untill last step.
When I am generating contours with contours generator transformer everything works fine, but I have in the area few lakes where I don't want to generate contours.
I've tried to use breaklines but when I am using it generally nothing change - contours still looks the same.
I have layer with lakes where I don't want to generate contours. Before connect it to Breaklines arrow in ContourGenerator transformer I am using geometry coercer and 3DForcer.
Can you guys tell me what I am doing wrong? I have no idea how to manage with this.
Screnshot below. Brown polygon is a lake.
Thank in advance.
Forum|alt.badge.img+49
I don't think you're doing anything wrong per se, it's just how the DTM interpolation works. What you can try is using a Clipper to remove the contours that fall inside the lakes.
  • May 10, 2022
Thanks for your answer. Is there any chance to remove also two nearest contours generated out of this brown polygon?
  • May 10, 2022
Generally what I want to do is generate contours but I don't want to get them (contours) in lakes/rivers areas and contours located on the edge of this lakes/rivers.
@bukakalke​ Have you tried experimenting with the Surface Tolerance? If you have the lake polygon, try adding that as a breakline (if you knw the Z value).
  • May 10, 2022
@Mark Stoakes​ Hey! I added lake polygon as a breakline and I added Z value with 3DForcer - you can see result on attached screenshot.
I've tried with surface tollerance like 0.5, 1, 2 etc. but nothing change...
