StoryMaps API in FME PythonCreator/PythonCaller
quangu
Hi!
Im looking for a way to import StoryMaps API to FME PythonCreator/PythonCaller. I have tried to import and read the following script:
"from arcgis.gis import GIS
from arcgis.gis import Item
from arcgis.apps.storymap.story import StoryMap
from arcgis.apps.storymap import Themes
from arcgis.apps.storymap.story_content import Image, TextStyles, Video, Audio, Embed, Map, Text, Button, Gallery, Swipe, Sidecar, Timeline"
When I read this script in PythonCreator/PythonCaller I got a message "Translation FAILED". The first two worked perfectly, but not the other three. Any ideas how i can work around?
Appreciate your help!
image1image2
birgit
Forum|alt.badge.img+16
  • May 10, 2022
Hi Quangu,
Storymaps support has only really been implemented since basically this month. Maybe you are using an older arcgis module? Try this in a new python caller:
import arcgis
print(arcgis.__version__)
If the version is lower than 2.0.0 then you need to update ArcGIS Pro first to get this working.
Also I think the problem you have is caused by the final comma on line 9. You should not put a linebreak there. If you do want to do that it should be: , \  I think.
quangu
  • May 10, 2022
It actually worked, when I updated to 2.0.0!
Thank you so much!
