I have extracted contour lines from an MBTILES file, the contour_line has contour_line_type and property_value the latter contains the height information. My question is how can I get these to export as tags in the way data in the OSM output file.
  • December 13, 2021
  • 0 replies
  • 29 views
When I applied a fan out to the writer the tags appeared correctly why don't they appear with no fan out?
Be the first to reply!
