Is there a way to 'quieten' the command line console when running FME from the command line?
james_c_452
Forum|alt.badge.img+7
I am running FME from the command line. I was wondering, because I've never been able to work it out, is there a way to make it so that FME does not report anything to the console window so there isn't as much text? Or at least less text?
For example I don't want to report all this progress text
2023-11-01
The way I am calling FME is like this:
fme WORKSPACE.fmw ^
--PARAM_1 ABC ^
--PARAM_2 123
Any help would be appreciated thanks
Best answer by david_r
I just tested the following technique, and it only outputs the single line "Translation was SUCCESSFUL" in the console when using FME 2023.1:
fme.exe myworkspace.fmw > nul
DanAtSafe
Forum|alt.badge.img+18
  • October 31, 2023
Hi @james_c_452​ Is that your exact syntax?  From the screenshot it looks like you're running it with
LOG_STANDARDOUT YES
at the end.  Which build of FME are  you using? Also, it looks like you're running a mapping file - you can run a workspace (*.fmw) from the command line too.
james_c_452
  • October 31, 2023
LOG_STANDARDOUT YES
Hi @danatsafe​ ,
Yes that's it (except it was a typo. I am calling an fmw file. I have changed that in the original post).
I have tried this also but it is still the same
fme WORKSPACE.fmw ^
--PARAM_1 ABC ^
--PARAM_2 123 ^
LOG_STANDARDOUT NO
  • November 1, 2023
james_c_452
  • November 1, 2023
That works a treat. Adding > nul works
Thanks @david_r​ !
