You can use either a Clipper transformer (with the shapefile as the Clipper feature) or a FeatureReader with the initiator filled by the shapefile and the spatial filter set to Bounding Boxes Intersect (probably followed by a Clipper, because intersecting bounding boxes doesn't necessarily mean the features intersect as well)
We use 3 different kinds of cookies. You can choose which cookies you want to accept. We need basic cookies to make this site work, therefore these are the minimum you can select. Learn more about our cookies.
