In an oracle database I would like to export to excel format a table with a particular filter. I would like to output only the rows containing the most recent date per section.
How can I do this on FME?
We use 3 different kinds of cookies. You can choose which cookies you want to accept. We need basic cookies to make this site work, therefore these are the minimum you can select. Learn more about our cookies.
