From a shapefile of 50,000 points, the final output on this would be polygons that contain 500 points per polygon. Appreciate any guidance on the best way to do this.
I have a shapefile of 50,000 points and I would like to split this out and create polygons around groups of 500 points. Can anyone help with the easiest way to accomplish this?
Best answer by geomancer
Also this blog post by @mark2atsafe on spatial sorting may be of interest.
