Filter out (with TestFilter?) records starting with specified word
scarter
Forum|alt.badge.img+9
Hello Group,
I have a polygon dataset of LSOA boundaries read into FME. It contains a field called ‘LSOA21 2021 name’. The values in that field are entries like 'Southwark e09', 'Lambeth e08' and 'Lewisham e13'.
I want to filter out only those records where the value begins with the word ‘Southwark’.
I’ve added a TestFilter with an If Test Condition of @Value(LSOA21 2021 name) CONTAINS_REGEX Southwark. But that is maintaining the entries where LSOA21 2021 name equals, for example, Lambeth e08.
I’ve been looking through https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_Transformers/!Transformer_Parameters/StringFunctions.htm, but couldn’t work out exactly what string I need.
Any ideas, please?
Thanks,
nielsgerrits
Forum|alt.badge.img+53
I would use the operator "Begins With" instead?
scarter
  • November 1, 2022
Thanks for that. I change the condition to…. [cid:image001.png@01D8EDF5.318ACCA0] … but I’m still getting results where LSOA21 2021 name equals, for example, Lambeth e08. Thanks,
scarter
  • November 1, 2022
Thanks for that. I changed the condition to…
Annotation 2022-11-01 132619… but I’m still getting results where LSOA21 2021 name equals, for example, Lambeth e08.
Thanks,
geomancer
Forum|alt.badge.img+47
  • November 1, 2022
Southwark-ish
scarter
  • November 1, 2022
Thanks for that. I've changed it to @Value(LSOA21 2021 name) BEGINS_WITH Southwark. Unfortunately I'm still getting records starting with Lambeth etc.
Annotation 2022-11-01 154414
geomancer
  • November 1, 2022
Not quite.... Left Value should only contain the attribute LSOA21 2021 name
The BEGINS_WITH is added in the Operator column.
Begins_With
geomancer
  • November 1, 2022
Which leads to
scarter
  • November 1, 2022
Thank you. That's resolved now.
