Dissolve polygons
  • September 27, 2022
  • 5 replies
  • 15 views
dxirgu
Forum|alt.badge.img+4
Hello,
I need to do a simple operation in any GIS software, like QGIS, but I can't replay it in FME, and then load this data on ArcGIS Server.
For example, I have two polygons with the same code (two rown in a data base) and I need to fusion them into a single one, using a common attribute, the code. The result would be two geometries and only one row into database.
If I use Aggregator transformer, checking group by this attribute, apparently the result is ok, but output a geometry collection don't load to ArcGIS Server. I tried to use GeometryCoercer, after the output port of Aggregator transformer, but it didn't work.
So, can someone help me?
Thanks!
danilo_fme
Forum|alt.badge.img+41
Hi @dxirgu​
Did you try to use the transformer Dissolver?
dxirgu
danilo_fme wrote:
Hi @dxirgu​
Hi @danilo_fme,
Yes, I tried, but output got more polygons than input.
Maybe I configured in a wrong way.
danilo_fme
dxirgu wrote:
Hi @danilo_fme,
Inspector
dxirgu
  • September 28, 2022
dxirgu wrote:
Hi @danilo_fme,
thanks for your help, but it didn't work, with this config.
imageOutput features get more features than incomming. In the next image, the correct number of features is from output port of Aggregator transformer.
dxirgu
  • October 21, 2022
Finally, I found out a solution. I used GeometryRefiner transformer after Aggregator transformer, to solve my problem. This worked for me.
