FME Server cannot connect to Oracle SDE --- Cannot connect to database client software failed to load. Be sure client software is installed and configure correctly. Oracle client is installed but still getting this error.
  • September 8, 2022
  • 78 views
The workbench connects and runs on FME desktop using same sde connection. Any help resolving this error would be appreciated! Thanks!
  • September 9, 2022
Have you checked that the bit-ness is the samme all over the board. Meaning that if you have 64-bit FME, you'll need the 64-bit Oracle client as well as the 64-bit ArcGIS libraries installed on the same machine.
  • September 9, 2022
Thanks so much for your answer. Turned out that a reboot after the installation of the oracle client was what we needed to do.
