Web Connections - Salesforce When you use a Custom Domain for Salesforce in FME, how do you check that FME adds the appropriate suffix?
  • December 17, 2021
  • 45 views
philipwhitten
Forum|alt.badge.img+11
When I add a custom domain for Salesforce in FME, FME is not adding or permitting the ?locale=au suffix. The formatted string should be https://p-2576944.my.salesforce.com/?locale=au but FME looks like it is using https://p-2576944.my.salesforce.com.Salesforce Suffix
Best answer by danminneyatsaf
philipwhitten wrote:
I can't connect to my Salesforce account through the FME Web Connection. When I attempt to connect with FME I get an "OAuth error". I can connect successfully connect to Salesforce using the Chrome browser from the same computer. So I am trying to understand why FME can't connect and at the momment and FME feels a bit like a black box - I don't know what tests to perform to learn what is going wrong.
@philipwhitten​ In this case you may need to check with your salesforce administrator if you have granted API access to your Salesforce account. This may require you creating a Connected App in Salesforce. To create a Connected App in Salesforce I have provided some instructions below.
For this you require a Client ID (Consumer Key in SF) and a Client Secret. To generate these, you'll need to get your SF admin to create a Connected App in SF (Setup > Apps > App Manager; there's a button New Connected App). You do need to be a Salesforce admin to create the Connected App.
salesforce-connected-appOnce the app is created in SF you should have a Consumer Key (Client Id) and Secret. The last thing to obtain from your SF Admin is the Authorization URL for your SF. By default it's set to https://login.salesforce.com/services/oauth2/authorize?response_type=code&scope=refresh_token full
Next, in FME, go to FME Options > Web Connections and Manage Services and create a new service from the Salesforce template we have. Here you want to populate a new Web Service Name; the Client Id (which is the SF Consumer Key); the Client Secret; and the URL domain to hit for the required URLs
salesforce-web-connection
danminneyatsaf
Forum|alt.badge.img+12
Hi @philipwhitten​, unfortunately it's not possible to check if FME has added the appropriate suffix. You say that it looks like FME is using https://p-2576944.my.salesforce.com, does this mean you are encountering errors when trying to connect to your Salesforce account through the Web Service Authentication?
philipwhitten
  • December 21, 2021
danminneyatsaf
  • December 21, 2021
philipwhitten
  • February 2, 2022
Thanks so much. Our connection is working now. In addition to your instructions, we had to change the URL's in FME because we are using a sandbox (test environment) and then we had to change the refresh token expiry policy in Salesforce to get it to work.
