Where I Put the condition for the FileCopyWriter?
franco69
I have for example 10 excel files in the sourcefolder that all be read from FME but only 8 files have the right basenames to go through the first tester and the rest of the workflow.......i want at the end move the excel sheets from the source folder in a destiantion folder....all that works already.....but now the filecopywrter move all files from the source folder......how and where i can put a condition that FME should only move the excel files which have the right basenames?
Cheers and greetz
Franco
j.botterill
Forum|alt.badge.img+36
  • October 4, 2023
How are you reading the excel files? Maybe consider using a FeatureReader with Directory and File Pathnames Reader (safe.com)
Using the path_windows or path_windows_directory and if you use another FeatureReader to read excel, be sure to accumulation - merge intitator and result.path_windowsThen I think you might rename this to filecopy_source_dataset before the File Copy writer
franco69
  • October 4, 2023
thx for the answer but i think my description wasnt the best at all.....my colleagues putting excel files into a fixed folder: (source) when workbench is started the reader read the folder and takes all *.xls files ! (normal excel reader)....the format attribute fme_basename i take with..........
then a tester checks if the basename includes "PA7"...........if the file does some transformers will make a split a write some excel files........the last action in the navigator is the filecopywriter which moves ALL excel sheets from the source folder into also a fixed folder (done).....
i want to be sure that the filecopywriter only move the files which had the fme_basename correct.....
screenshot_wb
j.botterill
  • October 4, 2023
screenshot_wb
perhaps play around with replacing the Reader <all> with the above suggestion of feature reader with Directory and File Path reader format.
add another feature reader and do exactly what the Reader <all> was doing. The feature reader has many additional options such as attribute handling = Merge Intitator and Result... this will keep the windows_path attributes. Under Generic you can expose attributesimage
